4 digit up/down counter
Mhine28
Joined Sep 2, 2014
10
i'm using 7447 instead of 74247..
is that possible?
and can that circuit be set to start to a certain number?
thanks for the reply.
SgtWookie
Joined Jul 17, 2007
22,230
So, this is an assignment for school. Why didn't you start off saying that?
Why don't you post YOUR circuit that you seem to be having trouble with?
We're not here to do your homework for you, as you wouldn't learn how to do it yourself. If you are really stuck and can't figure something out, we can help you past that point.
tshuck
Joined Oct 18, 2012
3,534
here is the schematic diagram that I found in the internet..
i couldn't make it work..
Is there any work you have done yourself on your homework?
Please make a legitimate effort on solving your homework problem first, before consulting the internet - including asking us.
tshuck
Joined Oct 18, 2012
3,534
no i didnt...
i said "I found" that means i searched that...
i was hoping that if someone can tell me why even if i connect the circuit it wont work...
One of two reasons it won't work:
1. You hooked it up wing
2. The schematic is wrong
There are many reasons that could have gone wrong in either process. For is to tell you what you did wrong would require knowing what you did - something you haven't been very forthcoming with....
35,177
I said "build this circuit", not "design this circuit".
We know you didn't design the circuit. We also know you didn't build the circuit.
So how do you know whether or not the circuit works?
MrCarlos
Joined Jan 2, 2010
400
Hello Mhine28
The circuit contained in the image that you enclose, is not quite right.
Look at the notes I added in it. (In black and red line)
Many of the circuits that we found on the internet do not work.
This is another case.
It is easier and faster if you look around here on the forums trying to find a Up-Down circuit that meets your requirements.
You also need to study the data sheets from the ICs you intend to use
You can get them at this link: http://www.alldatasheet.com/
Mhine28
Joined Sep 2, 2014
10
Hello Mhine28
thanks for the info.
and thanks for helping me out coz im just a newbie..
