4 channel momentary remote control
djsfantasi
Joined Apr 11, 2010
9,237
hey guys!
I may not have all the info I should, but I want to discuss a problem I am having.
I purchased a 4ch remote control module. It's power supply range is 5V to 10V. However, it's not putting out a high enough voltage when switched, to drive a CMOS AND gate. I measure about 2.5V. The vendor replaced the module once, but no joy.
I am driving it with a 9V battery, and a new one at that.
Any suggestion on troubleshooting?
GopherT
Joined Nov 23, 2012
8,009
hey guys!
Try a 10k pull-up resistor.
EM Fields
Joined Jun 8, 2016
578
hey guys!
Can you post a schematic of what you're working on and the module's data sheet (or a link to it) please?
djsfantasi
Joined Apr 11, 2010
9,237
It was a cheep Chinese module, and hence there is nothing to post. The schematic I am connecting it to is attached.
More info can be found here.
http://forum.allaboutcircuits.com/threads/game-circuit.82641/
Instead of pushbutton, I am using the outputs of the remote module. The module uses the same power source as the circuit, so they have a common ground. The aforementioned pull down resistors are on the schematic. It has 5 outputs. One for each channel and one that changes states whenever any of the 4 channels change state. The transmitter is a fob with 4 buttons, one for each channel.
