I'm thinking seriously about undertaking a project to build myself a 4-channel data logger. So far I've come up with some specs I want it to meet, and most of the hardware. If anyone has any ideas of what to take out or what to put in, I'm all ears (or eyes in this case).
Resolution: 12-bit
Accuracy: 0.1%, but I'll take 0.5%
Sample rate: Max of 4000 s/s, all 4 channels simultaneously. Selectable from 4k/s to 1 sample per minute. At slower sample rates each channel is averaged, up to 16 samples per reading.
Range: 2, 4, 8 or 16V.
AD780 reference for ADC, trimmed to 3.072v. The most accurate voltmeter I have is a EXtech 560 so my accuracy is totally dependent on that (0.03%).
LCD screen (NewHaven NHD-C0216CZ-FSW-FBW-3V3) for setup and showing channel values as they are read.
2MByte Flash chip (AT45DQ161) for storage.
Serial port for upload to computer, in CSV format. (No, not going to a flash card.)
A DPDT relay, for control of whatever I'm recording. (Like battery discharge, to shut off tester at some threshold.)
What else?
Resolution: 12-bit
What else?
