3V Low voltage RS Latch
seacrab
Joined Sep 28, 2016
I am looking for a simple positive logic RS latch that runs around 3 volts since it will interface with an ISD 1820 voice module. It seems like most IC’s run from 5 to 18 volts and I don’t want two power sources. Kind of a newbie as far as finding things.
Ian0
Joined Aug 7, 2020
13,317
An SR latch can be made from two inverting gates. 74HC00 and 74HC02 will run from 3V and do the job.
There are lots of 74series families that work down to much lower voltages (1.8V for instance)
38,952
One possible advantage of the CD4000 series is that they are relatively slow, so are less sensitive to high frequency noise, if that's a consideration.
sarahMCML
Joined May 11, 2019
707
Or (no pun intended) with a single OR gate, this one:
Using a CD4071B, it was quite happy at 2.4V switching one of my Superbright green LED's with a 22k series resistor to ground on the output, and a 10k for RX.
AnalogKid
Joined Aug 1, 2013
12,299
Here is a 555 Set-Reset flipflop with differing input logic polarities.
SW1 and SW2 can be combined into a single SPDT switch, either standard or momentary, with or without a center-off position.
ak
