I finally managed to sort out the array of bulbs needed to drain the battery at a rate of C2. It seems to work fine and it is interesting to see how the voltage changes as they are drained.
One thing I still don't know is when to stop as I know that draining the batteries too deeply will cause damage them. I simply stopped when the voltage as they were being drained dropped to 11 volts per 12 volt battery which they reached very rapidly. How deeply do I discharge them how do I know that they have reached that point?
Is there anything else that may be helpful such as subjecting them to a heavy load?
Thanks
Thanks
