MisterBill2
- Joined Jan 23, 2018
- 28,226
But if you do either of those and the voltage or the current is anywhere near the maximum specified, yo should watch the process carefully because conditions will change fairly quickly when charging a good battery, especially a smaller one. Also, feel it occasionally to see if it starts to get hot, and if it does, back off the charge rate.You can apply 1A and the battery will decide what voltage that produces across its terminals.
You can apply 16V across the battery and the battery will decide how much current that drives through it.
