I'm making a selectable power supply so as to need only one set of leads I want to have led indication on each leg. Do I just power the led from the output of each leg?do I need a boost converter off of each leg to compensate for led voltage?
New here, saw this and have to ask, why are you limiting your project to voltage 'selection'? Why not simply tap the 12 volts and make it adjustable from 1 - 12 as needed? You could even get fancy and add a simple analog meter at the vOut but be sure to use a dvm and adjust the set screw on it to insure it reads correctly.
