2xAA NiMH 800mAh Rechargeable Battery
dhinesh.ganesan
Joined Oct 19, 2017
48
Hi
I am designing a circuit for driving the stepper motor, the link attached (https://www.alibaba.com/product-det...m=a2700.7724838.2017115.17.149a279bsYy1CA&s=p) using 2xAA (2.4V) NiMH 800mAh batteries. Also, I am using a boost converter U1V10F5 (0.5V-5.5V)to step up from 2.4V to 5V to power up the motor as well as the driver (DRV8834). I've found that the motor that runs at 2.7V consumes approximately 70mA. The question is if I am using normal 2xAA(3V) battery or bench power supply (set it to 2.7V) the circuit is working fine and the motor is running. Whenever I set the voltage to 2.6V or 2.4V on the bench power supply or connect the 2XAA rechargeable battery my motor stops working.
Is that the rechargeable battery not having enough capacity? or the step up booster is not able to supply enough current to drive the motor at 2.4V?
Please let me know why the motor is not running at 2.4V and runs at 2.7V. I have attached the rough schematic. I am using two PSU for the microcontroller(5V@3A) and the motor(2xAA(2.4V)) indicated in dotted lines in the schematic. Your guide is much appreciated. Thanks in advance.Schematic.PNG
AlbertHall
Joined Jun 4, 2014
12,663
NiMh batteries terminal voltage is 1.2V. Two in series would give 2.4V. You have established that your circuit doesn't work at 2.4V so it's not going to work on two NiMh batteries.
What is the output voltage of the booster with a 2.4V input?
dhinesh.ganesan
Joined Oct 19, 2017
48
5v out
Do you think booster part is not having enough current ?
AlbertHall
Joined Jun 4, 2014
12,663
If the booster is providing 5V out then it doesn't seem to due to the booster. Equally if the stepper driver has a 5V supply then it ought to be working but isn't. On the face of it it is the stepper driver that has the problem but it does work when the booster input is higher.
Confused.
What is the booster output when its input is 2.7V?
bertus
Joined Apr 5, 2008
23,031
The step-up converter can handle a max input current of 1.2 Amps.
At 2.4 Volts input voltage I would expect a max output current of about of 0.5 Amps, if the batteries allow the 1.2 Amps input current.
I have the idea that the internal resistance of the batteries is the cause of the failure.
https://www.pololu.com/product/2564/specs
Bertus
ian field
Joined Oct 27, 2012
6,536
5v out
Ni-Mh are greatly inferior to Ni-Cd when it comes to instantaneous current draw.
When the Ni-Cd AA cell in my shaver gave up, I tried a Ni-Mh replacement - the run time of the 2400mAh Ni-Mh cell was about the same as the old knackered 600mAh Ni-Cd cell. The cell got warm, which was a clue to where the missing energy went.
A rechargeable lithium would make life easier, but they're dangerous if not charged correctly - you can get a USB/lithium charger PCB from eBay as little as 0.99p and no postage.
dhinesh.ganesan
Joined Oct 19, 2017
48
Confused.
5V is the booster output when its input is 2.7V
AlbertHall
Joined Jun 4, 2014
12,663
Still confused. The supply voltage to the stepper driver is the same whether the supply voltage is 2.4V or 2.7V, yet with a 2.4V supply it doesn't work. How does the stepper driver know what the supply voltage to the booster is?
dhinesh.ganesan
Joined Oct 19, 2017
48
That is the problem now. I have found that when you drop the voltage from 2.7V to 2,4V slowly using bench power supply, the current draw suddenly goes down to zero when it is at 2.4V and the voltage across the output of the booster collapses as well. Finally, the driver stops. When it is at 2.6V the driver struggles to drive the motor and the current consumption will vary towards zero. Any idea?
AlbertHall
Joined Jun 4, 2014
12,663
That looks like the booster cannot provide enough output current with only 2.4V input. Either you need to draw less current or a more capable booster.
