Dang, thanks all for the replies! I'm pretty good at fixing tube audio gear which is why I took on this project, but solid state stuff I am definitely still an amateur.
So I have ordered a couple 3055s and a couple 78S12s (mouser and Digikey don't have any 12V 3A regs with >18V max input voltage, for under $12...and at any rate I'm fairly confident the load on this circuit is under 2A).
I'm thinking to go with the regulator and just remove the unused zener, cap, and resistor. I'll report back if it doesn't work or there is some other fault I discover after restoring the 12V...
