24volt from pc power supply
scratch
Joined Aug 6, 2010
38
I live on a tiny island and it's very difficult to get none common items. Most of the time, it's DIY time.
thatoneguy
Joined Feb 19, 2009
6,359
So we will need to know the battery chemistry
This could get into a "hard spot" with line powered items and forum rules, with the desired current, it could be just an isolation transformer, rectification and filtering, followed by a combination buck converter/charge controller.
thatoneguy
Joined Feb 19, 2009
6,359
Why not charge them individually? Charging them all at the same time will result in some "topping off" before others, cutting the charge cycle short, making the problem worse.
Similar problem as multiple LiPo cell packs. Run taps to each battery and use 9 good battery chargers on them?
scratch
Joined Aug 6, 2010
38
9 battery chargers is Heavier & bulkier than one (on board EV) charger.
Onless very compact & in single housing.
Call it crezy if it is, I have just goten an idear of useing 1 charger switching (rapidly) sequentially to each pack.
R!f@@
Joined Apr 2, 2009
10,007
It seems u have two battery packs.
So can tell me the total capacity of each set. The total current and Voltage
PS. Do not expect to receive answers wit in few hrs pf ur post. Members are from all around the globe with different work times.
