24v from 12v psu elementary question
robinb
Joined Sep 1, 2017
12
hi
I have a meanwell 250w 12v PSU that came with a 200w 24v led light with a dimmer
The power supply gets Really hot
I emailed the manufacture who said the dimmer steps up the voltage to 24v with a voltage regulator
My elementary electronics knowledge tells me that I should only be able to at best get 125w at 24v
and so is overloaded
Do switch mode psu work in this way or am I missing something
Robin
robinb
Joined Sep 1, 2017
12
How much power would I be able to get via a 12-24v converter of some type ?
Is 125w in the ball park ?
robin
Dodgydave
Joined Jun 22, 2012
11,395
Your problem is when you use a converter, you use more current in the primary source to give the secondary supply, due to losses, so your led is 24V 200W, thats 8Amps output, so you're looking at drawing say 9 or 10 Amps.
robinb
Joined Sep 1, 2017
12
So I’m correct in thinking they would need to supply at least a 400w 12v psu and that the 250w unit is very underrated ?
Robin
