230v relay switching problem with rf
vijaybe
Joined May 27, 2014
1
I'm facing relay switching problem by using RF.I'm using the relay in RF Receiver side.I tried with RC snubber circuit in relay coil and relay contacts.But i can't find any solution for that.Relay switching time differs for snubber circuit(tried with different R and C combinations).
I couldn't switch the relay for right timing through RF receiver. Pls give solutions for this......
- - - Updated - - -
hi,
Here i'm using industrial gong bell as a load.
RF input is given to transistor base.
Alec_t
Joined Sep 17, 2013
15,156
There's your problem. You need DC on the base.
We don't know what voltage you intend to apply to R1, but R1=10k is probably much too high. Assuming your relay coil needs 100mA to operate, you need ~10mA base current.
