220 120 volt transformer
Rufinus
Joined Apr 29, 2020
325
Hello. I got a vacuum pump from USA. I'm going to use it in Spain. It said can work 60 or 50 hz so the only difference is the voltage. So can I use it using a step down transformer from 220 to 120 volts?
It is 1/ HP
Thank you
Janis59
Joined Aug 21, 2017
1,894
Rather sure, if feed from 120V 50 Hz it will be mush more heating-up than fed by 60 Hz 120 V. I wold guess You ought use the 50/60*120=100 Volts from 50 Hz thus the motor power will become 1.44x smaller, thus probably insufficient. May make an experiment. Switch that motor on 120V 50 Hz, but measure the current. As far the current arent overstepped that speciefied on the panel, You are in the safe side. Sometimes may happen that motor producer provided surplus turns into coils them be universal. Most of cheap motors are not like that, thus the most of US machines We cannot use in Europe in-spite of any best transformer existence.
Ian0
Joined Aug 7, 2020
13,291
An autotransformer should only be used if the motor has insulation rated for 230V, because it cannot be guaranteed that live and neutral will not be reveresed.
Reloadron
Joined Jan 15, 2015
7,960
It is 1/ HP
Thank you
Here you mention 1.0 HP.
Thank for your answer. Sorry I forgot to tell the power. It is 1/2 HP.
Then you mention 1/2 HP? Which is it?
I lived in Italy for several years. I got a great deal on a US Specification refrigerator (20 cubic foot) from a Navy family who was leaving. 240 / 120 VAC transformers were plentiful anywhere around a US facility. While the refrigerator was designed for 60 Hz it ran fine for 3 years on 50Hz. If you have a 1.0 HP vacuum pump a 1.0 KW transformer will work fine and if a 1/2 HP vacuum pump motor a 500 W transformer will work fine. In Spain anywhere around Rota transformers like this should be plentiful including used ones at inexpensive cost. A new 1 KW converter you are looking at about 81 Euros.
Ron
