2 similar elements act like an OR gate in reverse in a series circuit
38,819
I want that they act reversely, for example, one of them does not consume energy, but the circuit is ON, and vice versa
You requirements are still rather fuzzy.
How about two LEDs in reverse parallel connected to one series resistor.
Only one will be on, depending upon the applied voltage polarity.
WBahn
Joined Mar 31, 2012
33,196
Yes, but I need two similar elements that work in reverse, and at the same time, the current is maintained in the circuit
Again, just take two pieces of wire. Put them in series with one turned 180°. The circuit is "on".
Or use sufficiently-low-values resistors.
BobTPH
Joined Jun 5, 2013
11,651
You cannot have no current through one of them and current through the other, which appears to be what you are asking for.
