Does two pole filter in a buck or any other converter and use of small ripple approximation is the reason why we cant find ripples in output voltage?
For example in a buck converter
when I use small ripple approximation i am unable to find ripples in output voltage Vc(t). Is that due to two pole filter at the output? if so is the case, will i be unable to find ripples in H-Bridge
and current fed bridge
using small ripple approximation because there's a two pole filter at the output?
