I need to use 2 MOSFET(600 V each) in series , instead of using higher voltage one(1200V), so how I make sure that will turn off and on in the same time.
this a PFC circuit the input is 480 Vac and the output is 700 Vdc and current is 5AWhat are the voltages and current of the circuit?
View attachment 92987 View attachment 92987What is the circuit? You have a better chance of success if we know what it's going into.
I have the same idea with you, but I'm not sure what kind of the transformer can buy, are you sure the transformer can buy online or somewhere or you just provided an idea?
The transformer can be made on the ferrite ring. The parameters for the calculation, I took from my own experience. Optimization to reduce the size I did not do. In Scheme Hc=5 Bs=430m Br=100m and A=28mm^2 Lm=62m. Ferrite can take other parameters. I have approximate dimensions.I have the same idea with you, but I'm not sure what kind of the transformer can buy, are you should the transformer can buy online or somewhere or you just provided an idea?
Thanks so much you mean by the problem the RDS.You can refer to the circuit as below, the +12V2 and Mid is a another isolation power supply for the upper mosfet, the time delay could be happened in the Vgs, you need to through the testing and measuring to know how the affecting situation, maybe the delay time is too short and doesn't affecting anything.
If you need a 5A output then you should find a mosfet has 20A output is better, at least has 15A, the another issues are the Vgs and Id, when the Vgs=18V then Id =3A, that is shown in the SCT2450KE datasheet of your original mosfet.
Thanks so much , how you do the closed loop for your simulation , I mean how you make sure that the output will be 700v (if the input change or the load change , the out put will be regulated)
what will happen if the upper FET (FET1) turn first, in this case Vgs wiil be( 12-1200) so this will blow up the mosfet or will turn it off?You can refer to the circuit as below, the +12V2 and Mid is a another isolation power supply for the upper mosfet, the time delay could be happened in the Vgs, you need to through the testing and measuring to know how the affecting situation, maybe the delay time is too short and doesn't affecting anything.
If you need a 5A output then you should find a mosfet has 20A output is better, at least has 15A, the another issues are the Vgs and Id, when the Vgs=18V then Id =3A, that was shown in the SCT2450KE datasheet of your original mosfet.
Thanks so much , can you please explain how you get this numberThe transformer can be made on the ferrite ring. The parameters for the calculation, I took from my own experience. Optimization to reduce the size I did not do. In Scheme Hc=5 Bs=430m Br=100m and A=28mm^2 Lm=62m. Ferrite can take other parameters. I have approximate dimensions.
In this way, and can include three transistors.
The Vgs of upper mosfet only have 0V and 12V, that's why it needs a isolation power supply, if only anyone of the mosfet turn on then it could be blow up, so that's why it needs measuring and testing before connecting the load and HV power, I was thought about to using an AND gate logic conception to avoid this situation, but not have result yet.what will happen if the upper FET (FET1) turn first, in this case Vgs wiil be( 12-1200) so this will blow up the mosfet or will turn it off?
In the early days of solid state colour TV, the transistors available (BU205) wasn't quite up to the needed voltage rating - so most manufacturers used 2 in series. Each was driven by separate secondaries on a common driver transformer. Each base had a tuneable series inductor so the drive could be balanced.I need to use 2 MOSFET(600 V each) in series , instead of using higher voltage one(1200V), so how I make sure that will turn off and on in the same time.
A crude way of preventing that is a zener clamp from drain to gate, as soon as the drain voltage reaches the zener voltage; it pulls the gate up and the drain clamps any further voltage rise.When switching two elements in series like that it is common to put a resistor and capacitor in parallel with each so they form a voltage divider and protect the switches because if not the least difference in switching time means one switch will be destroyed by overvoltage (and the other one will probably follow).
