2 bits counter with JK ff
zestyphoenix
Joined Dec 9, 2015
3
Hey guys I need this circuit for my lab assignment tomorrow but I didn't get flip-flops really well. The circuit will count 00-01-10-11(in two seven segment display) when input is 1 and 11 to 00 when input is 0.
Here is a list of items that I can use:
ICs: 7400 (NAND gate) (x3), 74109 (KJ F-F) (x3), 7446 (BCD-Seven Segment Decoder) (x2)
 Switch (x3)
 Seven Segment Display (x2)
 470Ω (x8)
Anybody can post me a circuit that will work?
33,133
 Switch (x3)
 470Ω (x8)
So you don't want to put in any effort at all? You just want someone else to give you a circuit that will work?
MrCarlos
Joined Jan 2, 2010
400
Hello zestyphoenix
According to what I understand from what you say is that you were assigned to do an up-down counter 0-3, 3-0 with Flip-Flop's.
But. . . There are not very well understandable things in your statement:
Why two Display's ??.
Are you going you use a switch to the clock pulse ??. You'll need a circuit called de-bounce.
In the list of items that you can use:
The numbers in parenthesis are the number of ships or the amount of NAND gates, Flip-Flip's, switches ??.
33,133
I'm guessing that the two displays is because they want it displayed in binary (of course that can be done very easily without the use of a decoder (or, using a common anode display, without any logic at all provided the FF can sink enough current for four segments).
zestyphoenix
Joined Dec 9, 2015
3
Hello zestyphoenix
Two display because it will be in binary and yes the numbers in parenthesis are the number of that gates.
