thatoneguy
- Joined Feb 19, 2009
- 6,359
Those are transient voltage suppressors, which aren't the same thing as fast recovery diodes. The schematic seems to be relying on the body diode/parasitic diode in the MOSFET for spike suppression, which they aren't very good at. It's best practice to use a Schottky diode across source and drain, cathode/stripe toward positive.I've also noticed the P6KE68CA diodes seem to be letting 2.5 out of 3V through while testing, will this lead to a shoot through in the live system?
If the MOSFETs are switched on, they need to be switched off as well, otherwise the gate charge will hold them in the same state. So a high and low signal are needed for each gate, rather than a high signal and no signal.
