HI,
I have a project of two pics (18f4550 master and 18f4550 slave using spi )
the problem is when i start the simulation in Proteus I didn't find any problem , and everything is ok , But if I try to wire the circuit I got a corrupted data received in serial comm ?
could anyone please help me
the master code :
the slave code :
I'm using the following setting :
SMP = 0 ' Data input sampled at middle of data output time
CKE = 0 ' transmit of idle to active edge
CKP = 0 ' idle state is low level
SSPEN = 1 ' SSP Enable
and I am receiving the following in Serial com:
slave
000 255 255 255 255 255 255 255 255 255
slave
255 000 000 000 000 000 000 000 000 000
slave
slave
slave
slave
i have tried to use Pull up resistors for the SDO, SDI WITH 10K ohm but i
have received either 255 255 255 if i connect the resistor to the vdd
or 000 000 000 if resistor is connected to vss .
this is my Proteus simulation file in attachment
the master code :
Rich (BB code):
Device 18F4550
Xtal = 48
Declare Stack_Size = 10
TRISB.0 = 1
TRISC.7 = 0
TRISB.1 = 0 'MASTER
'TRISB.1 = 1 'SLAVE
TRISA.5 = 1 'SLAVE
TXSTA.5=1 ' setting Transmit Enable Bit
RCSTA.7=1
RCSTA.4=1
Hserial_Baud 9600 ' Setting Baud rate
INTCON=0
INTCON2=0
INTCON3=0
PIE1=0
PIE2=0
Symbol WCOL = SSPCON1.7 'Write Collision Detect bit
Symbol SSPOV = SSPCON1.6 'Receive Overflow (SLAVE)
Symbol SSPEN = SSPCON1.5 'MSSP Enable/DISABLE bit
Symbol CKP = SSPCON1.4 'SCK Release Control bit
Symbol SSPM3 = SSPCON1.3 '0101:Slave ss disableed,0100:slave ss ena
Symbol SSPM2 = SSPCON1.2 '0011:master clock=tmr/2
Symbol SSPM1 = SSPCON1.1 '0010:master clock=fosc/64 ,0001: fosc/16
Symbol SSPM0 = SSPCON1.0 '0000:master clock=fosc/4
Symbol SMP = SSPSTAT.7 ' Sample bit (INSLAVE =0 )
Symbol CKE = SSPSTAT.6 ' SPI Clock Edge Select
Symbol BF = SSPSTAT.0 ' Buffer Full Status flag
Symbol GIE_GIEH INTCON.7 'GLOBAL Interrupts enable
Symbol PEIE_GIEL INTCON.6 'SIDE DEVICES INTERRUPT ENABLE
Symbol SSPIF PIR1.3 'Parallel rad/write finish FLAG
Symbol SSPIE PIE1.3 'PARALLEL INTERRUPTS ENABLE
Symbol SSPIP IPR1.3 'PARALEL PRIORITY
Symbol CS = PORTB.7 ' chip select pin
SSPCON1 = %00100010
Dim i As Byte ' loop index
Dim Byte_Out As Byte
Dim Byte_In As Byte
Dim DataOut[30] As Byte
Dim DataIn[30] As Byte
DelayMS 500 ' Wait to stabilize
High CS ' unselect slave
Str DataOut = "give me the order hello",0 ' send to Slave
GIE_GIEH = 1
PEIE_GIEL = 1
SSPIE = 1
On_Interrupt GoTo Global_SPI
i=0
Dim t As Byte
Main:
HSerOut [Str DataOut,13]
For t = 0 To 3
SSPIE=0
Low CS ' enable Slave
For i = 0 To 26
'GoSub SPI_Function [DataOut], DataIn
SSPBUF =DataOut
While SSPIF = 0 : Wend 'BF WORK
SSPIF=0
DataIn= SSPBUF
Next
High CS
SSPIE=1 ' disable Slave
HSerOut ["master",13]
For i = 0 To 20
HSerOut [DataIn]
Next i
HSerOut [13]
'i=0
DelayMS 200
Next t
SSPIF=0 :i=0
'HSerOut [Bin1 SSPIF, " ",Bin1 BF," ",Bin1 WCOL," ",Bin1 SSPOV, 13]
GoTo Main
SPI_Function:
Pop SSPBUF ' pop directly to buffer
While SSPIF = 0 : Wend ' wait for end of transaction
SSPIF = 0 ' clear the SSP flag
Return SSPBUF ' push directly from buffer
Global_SPI:
Context Restore
Rich (BB code):
Device 18F4550
Xtal = 48
'SKAVE SETTING
Input PORTA
Input PORTB.0 'SDI INPUT
Output PORTC.7 'SDO OUTPUT
Input PORTB.1 'SCK INPUT
Input PORTA.5 'SS INPUT
RCSTA.7=1
RCSTA.4=1
Symbol CS = PORTA.5 ' chip select pin
SSPCON1= 0b00000100
Dim i As Byte '
Dim Byte_In As Byte
DelayMS 500
Str DataOut = "AAAA BB CCC DDDD", 0 ' Slave
GIE_GIEH = 1
PEIE_GIEL = 1
SSPIE = 1
Dim t As Byte
Main:
GoTo Main
Global_SPI:
If SSPIF = 1 And BF = 1 Then
i=i+1
DataIn = SSPBUF
SSPBUF = DataOut
SSPIF=0
If i = 26 Then
HSerOut ["slave",13]
For i = 1 To 26
HSerOut [DataIn]
Next i
HSerOut [13]
i=0
End If
End If
Context Restore
slave
slave
slave
slave
slave
slave
