Hmmm... in that case, if it were me I'd opt for the 450 volt part, just to be safe. Or "probably" safe...They're 200v 390uf.
I will go for the 630V but I have to measure the size correctly to make sure it will fit. I will report back. Thanks for your time sir.Hmmm... in that case, if it were me I'd opt for the 450 volt part, just to be safe. Or "probably" safe...
The "in circuit" comment means it runs its test signal below 0.65V and thus shouldn't turn on any nearby semiconductors. The measurement looks at how low the test signal gets pulled down by the cap. Lower voltage equals lower ESR..It says it is an IN-CIRCUIT tester. Does that mean it will also test a component by itself?
Consult the manufacturer's data sheet.Hi all,
Is this normal reading for a 150nf capacitor ? Please see the photo.
The MESR-100 meter doesn't measure the true ESR of a capacitor. Like many of these low cost ESR meters, it measures the impedance magnitude.Hi all,
depends on how it is measured.Is this normal reading for a 150nf capacitor ?
https://www.hioki.com/en/products/detail/?product_key=5539
I'd run right out and buy one, except it costs as much as half a car. If you need it you need it.https://www.hioki.com/en/products/detail/?product_key=5539
It's very handy if your job involves designing magnetics for switchers.![]()
It's a lot easier to convince your boss to buy the Hioki than this: http://www.keysight.com/en/pd-24051...50-120-mhz?nid=-33831.1089074.00&cc=US&lc=engI'd run right out and buy one, except it costs as much as half a car. If you need it you need it.
You can buy AD8512 or TL072. But you can you tell us the model number for this class- D amp ?I now have another suspect, and is the operational amp or op-amp module number JRC 072B 8014G since the audio output is very low
Wow, I would love to have one of these. Too many digits in the price for my shallow pockets.
