Turns out that the sensor is Hall Effect Proximity Sensor that is reading the gear and providing an unconditioned signal to the board.If the output of the gear detection is a square wave pulse, you can detect the rising and falling edge to increase the resolution x2 if needed.
Max.
Are you sure it will work, besides I considered mosfets the reason why I chose the optoisolators were because the mosfets are gonna get pretty hot operating for a longer period of time, I can probably find better ones, but the optoisolators should provide the same function.does it need to spin in both directions? If it only has to rotate one way, no need for an h-bridge. A single mosfet/switch would work.
Thread starter | Similar threads | Forum | Replies | Date |
Z | Selecting the right fuse for a 130VDC | General Electronics Chat | 2 | |
O | Powering a 130VDC motor from standard 120AC | Power Electronics | 12 | |
R | Sample driver DC motor 130VDC 12Amp. | General Electronics Chat | 10 | |
T | Need help wiring a 130VDC Gearmotor | General Electronics Chat | 12 | |
H | 115Vac to 130Vdc diagram for gearmotor | General Electronics Chat | 3 |
by Duane Benson
by Duane Benson
by Aaron Carman
by Jake Hertz
