Hello all,
Hope this is the right location to post these questions.
I'm looking at using a couple pre-made boards to handle UPS duties for my 12V network electronics. Searched around the forums already but not seeing exactly what I need - I don't want to make a circuit from scratch.
One of the concerns I have is switch time and what capacitor I might need to support the devices during failover if the device is not instantaneous. I'm not sure if any of these inexpensive boards are instantaneous and am looking to support a 5A load...
These are the couple I am looking at.
https://www.ebay.com/itm/284232250492
https://www.ebay.com/itm/383760213828
I also looked at some alarm modules, but those got pricey quick.
I was considering devices only that take input from source and battery and do not charge. I want to connect a low power charger directly to the battery when power is active.
The latter one can enable and disable the charger but, using a dedicated charger for the cell chemistry, I'm not sure I need that - or want to mess with setting the voltage on that board to kick the charger on at the right point.
Appreciate any thoughts, thanks!
-Pete
-Pete
