12V PSU voltage instabilities problem
kramzar
Joined Mar 7, 2022
35
I designed an electric vehicle charging station, that uses a 12V isolated AC/DC power supply. Unfortunatly, when high current is required (when i switch together 2 power relays), the voltage on the 12V line seems to dip for a fraction of a second. This is a problem, since it also causes the same effect on my 3.3V dc/dc converter that powers the MCU, that subsequently looses power and restarts. This does not happen often, but only when the relays are continiously turned on and off multiple times.
I am attaching the picture of the power supply schematic and the osciloscope measurments on the 12V line, at the moment the relays close.
The power supply that I am using is this: MP-LD05-23B12R2 https://si.farnell.com/multicomp-pro/mp-ld05-23b12r2/power-supply-ac-dc-12v-0-416a/dp/3583988
My question is what could cause this behaviour and how could i fix it?
My guess is that the power supply can not provide enough current and can not regulate the voltage. Is there a solution for this problem, that does not require a larger power supply? Perhaps a sufficiantly large capacitor can do the job?
Papabravo
Joined Feb 24, 2006
22,116
If you really want to go medieval you could use a common mode choke and a differential mode choke with appropriate capacitor networks between them.
