12v parallel camper van set up
Jmjones
Joined Aug 26, 2024
13
Hi. Im scratching my head here. I’ve got 2x12v 110Ah batteries connected in parallel connected to a Victron charger. Negative and power leads from battery 1 that connect to battery 2 read 14v unconnected. When connected to battery 2 voltage drops to 12.4v. Limited brain cells so easily confused
BobTPH
Joined Jun 5, 2013
11,515
What does battery 2 read when not connected?
It sounds like battery 1 is charging battery 2.
When connecting batteries in parallel, they should start at the same voltage.
bassbindevil
Joined Jan 23, 2014
922
If the batteries are similar capacity, charging in parallel should be fine. They'll only accept the charge they need.
Looking at the wiring, though, it's a good idea to have a fuse or breaker as close to the positive terminal as possible. Apart from safety, it's convenient to be able to shut off everything at once.
Jon Chandler
Joined Jun 12, 2008
1,595
A battery isolator would be the proper way to handle charging. Each battery takes the charge it needs. A switch on the output can isolate the batteries (chassis vs house in an RV for example) or bridge them together when needed.
Jmjones
Joined Aug 26, 2024
13
Thanks. I have 2 ready to fit.
Jmjones
Joined Aug 26, 2024
13
Despite checking the ohms with the cables showing zero the negative was full of verdigris. Renewed cable and now charging normally. Thanks for the input
MisterBill2
Joined Jan 23, 2018
27,508
First, the battery terminal voltage depends quite a bit on the state of charge. And the state of battery charge depends a fair amount on the connections to both the charger and the load. Consider that at ten amps, one milliohm resistance different results in ten millivolts difference.
ThePanMan
Joined Mar 13, 2020
918
While putting two batteries in parallel is a straight forward project, looking at the picture it's hard to tell exactly what goes where. Schematics is the language of electricity and electronics.
It's fairly easy to see the negative jumper between the two batteries but looking at the picture I see on the upper battery a whole lot more wiring going on; wires we know not where they go or what they do. As for seeing a battery at 14V, that's possible if the battery has just come off the charger. But if you're charging both batteries in parallel at the same time then both batteries should have an equal charge to them. If not then one battery is funky. 12.4V is what I'd expect to see on a used but healthy 12V battery when at rest (not being charged). 14V is what I'd expect to see when (on a car) the engine is running and the voltage can go as high as 15V shortly after starting the car. But quickly the voltage should drop (engine running) down to 13.6 to 13.8V.
What are the conditions you are testing at? Is there an engine running with an alternator? Have both batteries just come off a charger, charged independently? Were they charged while connected in parallel?
To see that kind of voltage (14V) something is up. A 12V battery shouldn't read that high at rest. What I mean by "at rest" is a battery that has not been charged for at least 12 hours and no load has been applied to it (aside from normal automotive memory maintenance and such things like a clock - etc.)
Jmjones
Joined Aug 26, 2024
13
I guess you didn’t read post #8, where he discovered the problem and solved it.
TS? Dodgy wannabe tech here.. Despite doing my best I regularly get a build up of verdigris on my connectors where I have to resolder connections after a year or so. I have no idea what I am doing wrong..
MisterBill2
Joined Jan 23, 2018
27,508
I am not familiar with the term " verdigris ", but if that is the same as corrosion buildup, it would be from using an acid type of solder flux, or possibly a wrong type of solder and too much heat. If it is on bolted connections, the trick is to first thoroughly clean the connection, then add some electrical connection anti-corrosion grease to cover it.
Jmjones
Joined Aug 26, 2024
13
Yes a corrosion build up after time just below and into the soldered terminals. thanks for the tip, I'll give it a go when it happens again
MisterBill2
Joined Jan 23, 2018
27,508
Solder flux of the wrong kind will do exactly that: flow down between strands and cause corrosion later, as it absorbs moisture from the air. It is often fatal in the more delicate smaller electronics assemblies.
