12v lights operated using 2 switches
Uilnaydar
Joined Jan 30, 2008
118
If you want to push UP to turn on (or off depending on region) in any location, it's doable but not with just wires and you'd be using a SPDT momentary rocker type switch with some electronics (smarts) to enable/disable a relay controlling the switch.
Bobtol
Joined Mar 1, 2019
8
Sorry, I don't understand your problem.
You wish to control the light from either switch, i.e. you want to turn the light on/off at one switch without having to go to the other switch.
Does it not do that?
Hi
No it only goes on if i switch both switches to the same way. i will try again today maybe i did something wrong Thanks
34,882
Hi
Stop. You are not doing anything wrong.
Your statement is inconsistent.
You state:
That implies that the light is off when the two switches are in opposite positions.
Is that correct?
