12V FAN speed control by temperature
malaval_ren
Joined Jun 4, 2020
MOD NOTE: New thread started from this post split from this thread.
Appreciate it thank you. Addin the updated schematic just to make sure I've done it right.
Also if there is a better solution based on whatever circuit, happy to explore that. Cheers
I'm looking a schema with usage of pwm pin, with low number of component without potentiometer, It's for my 1989 computer ;)
the temp is from 25°, in 3 or 4 step to max speed of the 12v fan.
Best regard
LowQCab
Joined Nov 6, 2012
5,102
Do You want a 12-Volt PWM Power-Controller ?,
or does your Fan have a PWM-Input-Pin ?
Do You already have a Temperature-Sensor ?,
if not, what type of device do You want to sense the Temperature of ?
Do You have a Spec-Sheet for your Fan ? ( please attach it )
