12V battery cables and connectors
ArakelTheDragon
Joined Nov 18, 2016
1,366
I have a 12V battery (120 A/h) its bigger than the standard car battery. I want to put 2 connectors on evey pole, 1 connector will be something like this:
https://www.delcity.net/store/Top-Post-Lead-Battery-Terminal/p_14433.h_100650
Under it I want to put a ring connector in order to connect the other end to the PCB.
The pole of the battery is about 19mm (I measured it with a ruler). But I can not seem to find a connector that has a 19mm diamater, all I see is 10mm-12mm maximum. Does such a thing even exist?
If not how should I put 2 cables on 1 battery pole?
