120V trigger to close dry contacts for .5 seconds
MotoLeon
Joined Oct 3, 2019
4
I have a Wyze smart plug that delivers 120V for 30 seconds before turning off that I need to convert to a half a second closure of dry contacts. (to open and close a garage door). If anyone could propose a simple circuit that could accomplish this I would appreciate it.
Thanks in advance,
Leonard
ElectricSpidey
Joined Dec 2, 2017
3,340
Diode…capacitor…capacitor…relay
I’m not at my computer where I can make the schematic, but basically you rectify the 120 volts AC half wave, filter it, then place a capacitor in series with the relay on the output to give a short pulse output.
Oh yea, and a resistor across each cap for discharge.
MotoLeon
Joined Oct 3, 2019
4
Oh yea, and a resistor across each cap for discharge.[/QUOTE
MotoLeon
Joined Oct 3, 2019
4
Thanks for the quick reply! This is inline with what I was thinking. I would have loved to see your schematic with some value....maybe if you get a chance!
Thanks again,
Leonard
38,555
Below is the LTspice simulation of the circuit proposed by ES.
The yellow trace shows the relay closure time.
R1 is the resistor to discharge the caps after the AC stops (it should be 5W rated).
The value for C1 depends upon the coil resistance of the 120V relay you select (the value of C1 times the coil resistance should be 800ms or greater to get a ≥500ms relay pulse).
