120v to 13.v input hardware
newb777
Joined Aug 20, 2023
So I'm building a battery box.
Specs are:
(2) 12v12ah sla batteries
(1) 5v2.1ah USB outputs.
(1) 12v dc output (car charger)
So my question is what part do I need to put power into this thing. I could go cave man and put some posts on the top of the thing and hook a car battery charger up to it, however I want a better and more elegant solution.
I can find numerous amounts of wall plug chargers but I can't find the damn parts the wall chargers plug into. I need good recommendations for the actual part(s) a 120v to 13.5v wall chargers plugs into.
I would like to use something like a USB c type wall charger or maybe last gen mini usb
Any help would be greatly appreciated.
Jon Chandler
Joined Jun 12, 2008
1,629
You could use a USB C PD charger with 45 – 60 watts available from a single port; this provides a 20 volt output at 2¼ to 3 amps.
You'll need a 20 volt USB C PD "trigger" which negotiates with the USB C PD charger to provide a 20 volt output. The triggers have a USB C input connector and are hardly bigger than the USB C connector itself.
To drop the 20 volts to the needed voltage for charging the 12 volt battery you'll need a switching buck mode module.
As far as what's needed for regulating the charge, I'll leave that to others.
Here are links to a PD trigger and buck converter that I'm using with a PD supply to operate my CPAP. Not all PD chargers support 12 volt output, so I opted to use the 20 volt output which is part of the current standard. Using a PD charger reduces both the volume and weight by a factor of 4 compared to the standard 12 volt supply, and I can use the same supply to power my laptop and charge my phone.
[Url = https://www.amazon.com/gp/aw/d/B0B688SKNK?psc=1&ref=ppx_pop_mob_b_asin_title]PD trigger[/url]
Buck Converter
