120ac to 220ac
Reloadron
Joined Jan 15, 2015
7,977
I have no 220v outlets I my house. I have a few audio projects that require 220v. How can I achieve getting 220v.
Well option A would be to purchase a step up transformer rated for the power you want or need. As your power demand increases the price will follow. There are also step up converters. A simple Google of "120 volt to 220 volt step up transformer" should get you results for both. Just make sure if you use a converter type device or inverter type that you have a TSW (True Sine Wave) output unless you can do with other wave shapes.
Option B is most N. American residential power delivery is 240 VAC 60 Hz so if you can live with 240 VAC 60 Hz it's available. Just a matter of running a line from the entry circuit breaker panel to where you want it. Wire gauge and insulation to be determi9ned by how much power you want or need.
Finally there are rules.
Note that the transformer can't deliver more power than the 120Vac outlet, which is typically about 1500W in the USA.
Need to work in the rules. :)
Ron
28,576
Many folks suggest using a step-up transformer.. None of them asked for the power or the required current rating, although many suggested being adequate for the requirements.
My first question would be how much current does the device require??
Consider that in most residences the mains supply is 220 or 240 volts, split into two 120 volt branches. Adding a 220 volt outlet is not so terribly complex. but certainly it requires an understanding of what is involved.
panic mode
Joined Oct 10, 2011
5,458
projects? like DIY circuits (amplifiers)? none of them require AC, all audio equipment is ultimately powered by DC.
my question would be what DC voltage is derived from 220VAC. just get proper supply that produces that from 110VAC
iamtheone33339
Joined Feb 13, 2024
18
I have a power filter board that requires 220vac input
28,576
The attachment shows a POWER SUPPLY module feeding an amplifier module. A "power filter" is not likely to need a specific supply voltage. The power supply shown is a switching mode supply and it may deliver adequate performance even with the lower supply voltage.
One very confusing thing is that the attachment shows the mains power supplied to both the power supply module and the audio amplifier module. THAT does not make sense as I see it. In fact, the more closely I examine that image, the less sense it makes. Is the TS able to provide us with the markings of the terminals on those modules?? And any possible link to the on-line descriptions?
iamtheone33339
Joined Feb 13, 2024
18
It's a 12v aux for the fan
What do you mean by "a few audio projects that require 220v"?
Give us specific details.
An audio power supply filter board that requires 220vAC input . The above picture has the info
35,299
The board requires 240ac input and gives +-65vdc and 12vdc output. So what your saying is I could just use 120vac input
That is not what I am saying.
We have been given no data on the board so we don't know what the board does.
Without that information I say get rid of the board.
You are saying that your audio equipment needs +/- 65VDC and +12VDC. Then give it that.
240VAC is a red herring.
28,576
If it is a 12 volt feed for the fan the why does the picture say AC 220v??With a description like that, I WOULD NOT BUY IT EVEN IN A STORE WHERE I KNEW FOR CERTAIN THAT THEY WERE HONEST.
That description drawing does not match the words, not even close.
