12 vdc timed momentary
JD1979
Joined Nov 14, 2024
I am looking for a device that once 12vdc is applied a 10-15 second timer is started to initiate a momentary closure. No power transfer just a momentary closure of .5 seconds. Anyone know of something simple? Thanks in advance.
meth
Joined May 21, 2016
327
I dont know if you have availibility of components where you live, but if you can buy an OFF DELAY TIMER RELAY that should solve your problem.
Reloadron
Joined Jan 15, 2015
7,977
Not knowing what the load is?
A simple Google of "timer relays" will bring up a dozen hits of modular off the shelf inexpensive timing solutions including delay on make, delay on break, repeat and one shot as well as others.
Ron
28,576
To make the intention clear, you seek a timer that after a variable delay of 10 to 15 seconds after power is supplied, provides a contact closure for 0.5 second. Then the contacts remain open.
AnalogKid
Joined Aug 1, 2013
12,294
What is the open-circuit voltage across the "closure" circuit / device / whatever - ?
What is the closed-circuit current?
ebay timer module with isolated relay contact outputs - approx. $5 US.
ak
28,576
Getting a half second pulse will require some sort of second timer function, which may add some complexity to the project.
How accurate do the time periods need to be?? And what sort of load current will the contacts be controlling? There is a really simple trick to get a single pulse, if the load is isolated and at a specific voltage.
