12 Digital Bit Generation at rate of 5M Samples per Second
nigavesuraj
Joined Feb 21, 2018
Hello all,
In my project, I want to control 12 digital bits at rate of 5 MHz.
Please suggest me which micro-controller should I use for this application.
Micro-Controller has to work on 1.8Volts or 3.3Volts DC power supply.
35,175
It is not clear what you are trying to do.
Are you sending digital stream at 5MHz, or are you digitizing an analog voltage at 5Msps?
nigavesuraj
Joined Feb 21, 2018
Thanks for reply.
And sorry for confusing the things...
I want to send 12 digital bits at rate upto 5Hz(It may be 1MHz, 2MHz, 3MHz, etc.)
There is no relation of Analog to Digital conversion, ADC, Sampling rate, etc.
For reference I'm attaching the updated system requirement block diagram.
BobaMosfet
Joined Jul 1, 2009
2,211
Your max rate whether serial or parallel means you have to transmit something (1 bit for serial or 12 bits if parallel) within 195ns. How much work you expect the micro-controller to do beyond simply sending will determine which you choose. I would recommend 32MHz or faster, perhaps an ARM Core M3.
35,175
If you want to minimize the signal interconnections then you want to go serial with SPI or I2C.
20MHz clock rate is not uncommon. What is the physical separation between the two subsystems?
