10mhz timebase osc
dendad
Joined Feb 20, 2016
4,642
The output level may not be enough to trigger the 74LS14. It needs to swing above and below the required thresholds. That could be the problem.
dendad
Joined Feb 20, 2016
4,642
I think the signal needs to swing between about 0.8V to 1.8V for the 74LS14 to operate. So, a full 5V swing is not needed.
dendad
Joined Feb 20, 2016
4,642
You could try to have a resistor divider on the input of the 74LA14 to set it to about 1.5V, and then connect the oscillator signal to it via a 10nF capacitor.
Try a 2K2 from input to 0V, and an 8K2 from the input to +5V.
This may (or may not) work.
michael8
Joined Jan 11, 2015
472
radioshack5209
Joined Nov 25, 2020
68
Kevil
Joined Jun 28, 2020
224
Don't mess with all that active and passive components. Use MEMS oscillator which gives you reliable perfect rectangle signal with just one IC.
LSE MEMS Oscillator 32.768 kHz, IM890-IDCC-32.768 ILSI:
Deleted member 115935
Joined Dec 31, 1969
0
I must first say,
WELL DONE YOU,
its amazing how few people now days know what an oscillator circuit is , till they make one by mistake when they thought the were making an amplifier.
Second
The reason most people don't make or understand oscillators, is as @Kevil says,
off the shelf much better oscillators are pennies,
just have hunt on ebay for good enough, or your distributor such as digikey for good parts at a few pennies more.
Ian0
Joined Aug 7, 2020
13,317
You could always amplify it with a 74HCU04 with a 10M resistor across it, but you didn't have any 74HC; because if you did, you could have made the ever-so-reliable Pierce oscillator.
