100 foot RF door bell needed
Please excuse me for using this site as Comsumer Reports, but I need a remote control door bell for a fragile old lady. She bought one that said, "100 foot range" on the box, then I checked it out and it failed 4 out of 5 times at 25 feet, line of sight, no obstructions.
What I really need is, through two wooden doors, around 2 corners in a cement block structure, at about 50 feet. Anybody seen an aftermarket, remote control door bell that actually works?
ps, the definition of this is: a battery operated, push-button, RF transmitter that is mounted by the front door, and a battery operated receiver that rings a bell if it detects the signal.
Please, no fair reciting the advertising on the box. Only reply if you have used one and found it to be adequet.
Thank you, #12
Just bumping this because I found one the customer likes and I will go get the brand name of it tomorrow and post it for all of you.
Metalmann
Joined Dec 8, 2012
703
On a whim, I bought one like Spinnaker posted from China, for less than $6.00.
It works great for 25-30 feet, but haven't tried it at any further distance.
inwo
Joined Nov 7, 2013
2,419
The cheap send/rec. button modules on Ebay go 100 yards easy. (at least mine do)
Just in case you can't find a doorbell.
Read a little slower inwo. It's installed and the customer likes it.
It's called Utilitech #0077745
I bought it at Lowes.
Labeled for 100 feet.
To get matching ringers, you look for a small white sticker with something like 13SE52
That's the code to match the button with the ringers.
It's installed at about 40 feet with 3 cement block walls in the way.
Previously, I bought some other brand rated for 100 feet and they wouldn't work consistently at 25 feet with no obstructions.
Very bad results compared to the label!
30,681
On a slightly allied note, I needed the reverse, the door bell to operate the remote, this was due to the fact I work in up to 3 locations on the property and often get deliveries from UPS/FED-Ex etc that require a signature, If I don't hear the bell I have to get the guy to come back and hopefully I am around to hear it the next time?
So I carry a portable receiver around to where I am working, similar to Ono's unit.
I wired it so the Bell push also triggers the transmitter, I have a 9v battery operated receiver with surplus audio unit from a toy or some such, When the door bell goes I hear 'Start her UP' :D
