It's hard for me to ignore this.On second thought, I'm not ready to even ask this question yet. Please delete.
It's possible you only need a firmware cutter/installer. This is the case with some Broadcom adapters. Under Debian, the package is called b43-fwcutter, I think. I haven't used Redhat in a looooong time, so I don't know what their comparable package is.I'm running V16. Maybe updating to V21 may work. I'll give that a try soon.
I've used Linux for years, but someone else always set them up. And so, I'm setting up my first system. I don't know what firmware cutter/installer is, but I'll get together with google later and find out.It's possible you only need a firmware cutter/installer. This is the case with some Broadcom adapters. Under Debian, the package is called b43-fwcutter, I think. I haven't used Redhat in a looooong time, so I don't know what their comparable package is.
I've given up on such kludges and used gear from people who will let others write proper drivers for Linux.I've used Linux for years, but someone else always set them up. And so, I'm setting up my first system. I don't know what firmware cutter/installer is, but I'll get together with google later and find out.
???sudo yum update kernel kernel-headers kernel-devel gcc
HI Bertus,Hello,
Perhaps the following page might help:
http://www.linuxproblems.org/wiki/Enable_Netgear_WNDA3100_USB_Adapter_on_Fedora
The link to the driver seems to be dead, but in the internet archive I found the page:
http://web.archive.org/web/20131110113423/http://wireless.kernel.org/en/users/Drivers/carl9170
Bertus
Yes. An internet connection is required to perform updates and such (including installing ndiswrapper if necessary).OK, so I put this on hold and decided to get the wired network working, since it seems I need to be connected to do updates and such, or at lease I should be connected.
I like to do a new installation *near* the hardwired source. I can always move the box later. Just sayin'...So, I ran cable to the back of the house, where my 'new' lab is.
Wow. This is the first time I've seen a wired NIC that doesn't have native support. You have some weird hardware! I found this thread:However, it appears I don't have drivers for my network device (Atheros Communications Device 1091.)
What fedora and kernel version are you using? Without connectivity, you may be relegated to burning a newer install image onto a cd/flash drive and reinstalling fedora. Or, you could just get another NIC.52 moshe nahmias 2013-07-28 12:53:47 EDT
Just updated the system and the card works out of the box with kernel 3.10
I am with fedora 19
Quite possibly, yes. But consider it a learning experienceSo, I'm back where I started.
You'll need the network for anything that doesn't already come preinstalled in the original image.I've looked for solutions. There seems to be different ways to go about this, but I think I need a network for some of the solutions.
Yes, but you'd need to get the source packages and the build tools. I suppose you could use "sneaker net", but it'd be easier and quicker just to reinstall. It is relatively rare these days to have to "make" a driver. I've not needed to do it for years!And I think I might need to run make on the deivers, or kernel (or both).
Take this experience and keep it in your pocket. You'll find it useful in the future.I want to pursue Linux as a development system because I believe it makes drivers easier, that is if I ever get it working.
It's just a common GigaByte GA-78LMT-S2P purchased at CompUSA. I'm trying to use the device on the MB, and not a card. Nothing at all special about it. Next thing to try is to update the OS using a thumb drive. I don't know just yet how to do that. I tried using a CD but was unsuccessful. I think the OS didn't fit within the 700MB of the CD.Wow. This is the first time I've seen a wired NIC that doesn't have native support. You have some weird hardware! I found this thread:
UNetbootin is what I typically use to make a live USB version of a Linux OS, which will allow you to run the OS from the USB drive, or install it into the computer.It's just a common GigaByte GA-78LMT-S2P purchased at CompUSA. I'm trying to use the device on the MB, and not a card. Nothing at all special about it. Next thing to try is to update the OS using a thumb drive. I don't know just yet how to do that. I tried using a CD but was unsuccessful. I think the OS didn't fit within the 700MB of the CD.
If Debian has ALX, then my device should be supported....
My personal choice for a rock solid production server is Debian. The 'stable' release is a little behind the latest and greatest (which is great for mission-critical machines) while 'testing' usually is very current. I mainly run 'unstable' on coding machines to have the latest versions of everything. Debian 'unstable' is actually much more stable than most other distros main releases.If Debian has ALX, then my device should be supported....
I'm in the process of trying this. Report upcoming.UNetbootin is what I typically use to make a live USB version of a Linux OS, which will allow you to run the OS from the USB drive, or install it into the computer.
