(((7||8)+6)||5)+4 is that correct
Thread Starter bhuvanesh Joined Aug 10, 2013 268 Jan 28, 2014 #1 (((7||8)+6)||5)+4 is that correct Last edited: Jan 28, 2014
ericgibbs Joined Jan 29, 2010 21,572 Jan 28, 2014 #2 hi bh, What value do you calculate to be the total resistance.?? Is that circuit diagram complete.? E
LvW Joined Jun 13, 2013 2,037 Jan 28, 2014 #3 bhuvanesh, don`t you think it would be appropriate to spend some minutes for asking a question? Or do you want no help? EDIT: This answer was written before the OP has added the last two lines. Last edited: Jan 28, 2014
Thread Starter bhuvanesh Joined Aug 10, 2013 268 Jan 28, 2014 #4 http://www.calvin.edu/~svleest/circuitExamples/superposition/images/example1.gif i am in way to find voltage across 5 .i have calculated 7 and 8 in paralel and calculated the result in series with6 then what to do.
Thread Starter bhuvanesh Joined Aug 10, 2013 268 Jan 28, 2014 #5 i didnt notice a return path of 5, 6and 7.thank you all
ericgibbs Joined Jan 29, 2010 21,572 Jan 28, 2014 #6 hi, So have you now managed to answer your question.? I have posted the correct image as per your link, its very different from your original image. E Attachments example1.gif 2.5 KB Views: 29
Thread Starter bhuvanesh Joined Aug 10, 2013 268 Jan 28, 2014 #7 thanks eric. i have managed this time.but lot to go through.soon i may step here again .thank you
