555 frequency issues
nzemke
Joined May 12, 2012
9
I have been looking around everywhere trying to figure out what I did wrong with my calculations and I'm hoping that you can help me.
I'm trying to create a square wave oscillator at a frequency around 31,000 hz. I put together a little excel spread sheet to do the calculations for me. I took the calculations from the http://www.kpsec.freeuk.com/555timer.htm website. The calculations are as follows:
F = (1.4/((R1 + (2 * R2)) * C1))
R1 = 10000
R2 = 17700
C1 = 0.001 uf (102 cap)
I have this setup on a breadboard and it works but it gives me a frequency of 11.8Khz.
One question I have is if the C1 has to be an Electrolytic or if you can use a ceramic?
Really confused and hoping that someone can point out my error.
Ron H
Joined Apr 14, 2005
7,063
I don't know what your problem is, but it is probably either a measurement error or a component value error.
I don't think you will find a 1nF electrolytic capacitor. 100nF is the lowest value i have seen.
What kind of cap are you using, i.e., ceramic, mica, polyester, etc.?
35,321
The 555 formulas are guidelines only. I would not be too concerned if you do not get exact results. Remember, your capacitance can be off by as much as 20%.
You should not use electrolytics for the timing capacitor, C1, if timing is critical.
Try to reduce R2 to around 10K.
Ron H
Joined Apr 14, 2005
7,063
11.8kHz vs 31kHz is not just a component tolerance problem.
nzemke
Joined May 12, 2012
9
Tracecom, I'll put together that circuit this afternoon and see if I'm getting a better result.
Thanks everyone for the assistance!
Wendy
Joined Mar 24, 2008
23,869
R1 is a 10KΩ, R2 is a 2.7KΩ (red violet red). Is it in parallel with the 15KΩ? I see no 17.7KΩ resistor. C2 is for noise control, you can remove it in a small circuit with no effect what so ever.
tracecom
Joined Apr 16, 2010
3,944
tracecom, I noticed that you are using the ne555n chip and I'm using the ne555p, will this cause issues?
No, the two are functionally identical.
BTW, if you don't need a reset function, you can eliminate SW1 and R3 in my schematic and tie pin 4 directly to Vcc.
Wendy
Joined Mar 24, 2008
23,869
I find it interesting the OP is getting 11.8Khz, and should be getting 5.04Khz. It is a X2 difference. I am really suspicious of instrumentation error, the frequency counter. Have you looked at the waveforms with an oscope? I'm thinking it is that or a hard to spot wiring error. 555's are extremely predictable.
Ron H
Joined Apr 14, 2005
7,063
Bill, I think you have combined two posts. In post #1, he says he is expecting around 31kHz, and is getting 11.8kHz. There is nothing wrong with his equation, and if you plug in the component values, you get 30.8kHz. A sim gave me 31.5kHz.
takao21203
Joined Apr 28, 2012
3,702
w/o transistor this circuit will readily blink.
I changed components:
2 diodes from a television PCB, don't know 1n4148 or whatever
68K/1uF -> fast blinking, 10Hz
5K adjustable resistor not 2x 220 Ohms
Is there any reason why you need to calculate frequency?
Just any kind of capacitor will do.
