Buiding an electromagnetic field
baby_1
Joined Jun 3, 2011
39
Hello
i want to create an electromagnetic filed that can move a object with a a weight.could you explain me how can i do that and what is the formula?
baby_1
Joined Jun 3, 2011
39
Thanks panic mode
but i can understand what should i do?
for example i want to move a 1kg object and now that the diameter of wire.how can i calculate the number of round , core and formula that show me the relationship between this formula and the weight of object
pilko
Joined Dec 8, 2008
213
There are several factors effecting the force required.
- Distance from magnet to load
- Material of load
- Shape of load
- Atraction or repulsion?
pilko
Wendy
Joined Mar 24, 2008
23,800
Electromagnetic radiation is not going to be of much help I'm afraid, though magnetic forces could get you there (as in electromagnet).
panic mode
Joined Oct 10, 2011
5,129
force developed by magnetic field must exceed force of gravity (weight of object) in order to cause lift. But this means that target object must have own magnetic field in order to interact with field you create externally.
W=m*g
where
m=mass of object (kilograms)
q=acceleration due gravity (9.8m/s^2)
W=weight (Newtons)
Btw, everything you need is in (or can be derived from) equations I posted.
in general, force on conductor in magnetic field is:
F=I*LxB (this is direct result of F=q*vxB)
where 'x' is cross product
I is current in a conductor
L is length of conductor
B is magnetic field vector in region where conductor is
q is charge
v is velocity vector (note that his is VECTOR, it has magnitude and direction).
or simply
F=B*I*L*sin(θ) (here using magnitudes only)
where
θ is angle
this is for single conductor, normally you would use coil with multiple turns where N is number of turns of wire. using multiple turns we can increase magnetic field of repelling coil.
Btw
B=μH (so using ferromagnetic core with high μ helps)
from Ampere's Law we get
Integral H*dL = I
and as mentioned before using multiple turns your effective current increases to N*I
DC voltage is nothing. it is only needed to exceed resistance of the wire in your coil so you get current you want. Current is everything.
ceidas
Joined Dec 26, 2011
50
What? You want to say that when I am taking a magnet and lift in the air some iron needles, the needles already had some magnetic field of their own?
panic mode
Joined Oct 10, 2011
5,129
no, that is attractive force.
it was never specified that objects to be lifted are ferromagnetic and if lift has to be gentle or if it is ok to result in collision.
btw. if those needles never develop their own magnetic field (such as induced magnetic field), you will not be able to pick them with a magnet. there... ;p
Brownout
Joined Jan 10, 2012
2,390
@baby1,
I think I understand your question. All of the answers that have been given are great for calcualting MMF and so forth, but I think you want to know what force would act on an object that results from the MMF or magnetic field. Unfortunatly, I don't have the answer. Once or twice I tried to find out, but always came up short. That best answer I can give is to use the equations given to maximize the field strength, MMF, and the experiement with different objects. Please report your results. I have an interest in this too.
ceidas
Joined Dec 26, 2011
50
Firstly, I know four forces in the nature. Gravity, electromagnetic and nuclear. I dont know that "attractive force" of yours.
Secondly, you said "that target object must have own magnetic field in order to interact with field you create externally". If you take two metals and bring them together, will you observe any magnetic interaction? No. But if you bring them close to a magnet and then force an interaction between them, will you see any difference? Yes, because now their magnetic domains are not messed up.
So, the needles didnt have any magnetic field, they got it after the interaction with the magnet.
panic mode
Joined Oct 10, 2011
5,129
"target must have field to interact" so what?
where does it say that own field has to exist before object is excited?
you may want to recount those four forces.
ceidas
Joined Dec 26, 2011
50
You said that a field has to exist in order for the object to interact and I am saying that this is not correct.
Why do I want to recount the four forces?
Wendy
Joined Mar 24, 2008
23,800
Electric force and magnetic forces can be combined to make electromagnetic, but they also exist separately.
ceidas
Joined Dec 26, 2011
50
Actually, when I said electromagnetic I meant the force an electric field and a magnetic field can cause, but since they are closely related to each other I simply mentioned them as electromagnetic force.
WBahn
Joined Mar 31, 2012
33,019
Generally the four fundamental forces that act at a distance are given as the gravitational, the electromagnetic, the strong nuclear and the weak nuclear forces.
I recall in E&M II when, after nearly a semester of calculating magnetic fields, the professor came in and said, "Today I will show you that there is no such thing as a 'magnetic field'." and then proceeded to prove it.
