High voltage capacitors + diodes
Status
Not open for further replies.
wauuw
Joined Oct 2, 2011
Hello, I'm working on a Tesla coil driven by an car ignition coil.
The ignition coil puts out a few kV AC, so I need to rectify it. Previously I made a recitifier out of 20 1n4007's (5 between AC and +, AC and - etc).
That worked alright, my high voltage capacitors were charging, but when they discharged in a spark gap, the diodes broke down. From what I've read should for example 2 1n4007's in series withstand 2kV of reverse voltage (2 x 1000). So my question is this, if I make a rectifier of say 200 (50 x 4) diodes, will each terminal (AC to + etc) withstand 50kV?
Cheers,
wauuw
Joined Nov 30, 2010
18,224
First, I think this is too dangerous for this forum and might be shut down by the moderators.
Second, a long string of diodes needs to have their reverse voltages equalized with a bunch of parallel resistors.
Third, there must be a better diode for this job.
Good luck and don't kill yourself.
bertus
Joined Apr 5, 2008
23,014
I am closing this thread as it violates AAC policy and/or safety issues.
Quote:
6. Restricted topics. The following topics are regularly raised however are considered “off-topic” at all times and will results in Your thread being closed without question:
  • Any kind of over-unity devices and systems
  • Automotive modifications
  • Devices designed to electrocute or shock another person
  • LEDs to mains
  • Phone jammers
  • Rail guns and high-energy projectile devices
  • Transformer-less power supplies
This comes from our Tos:
Terms of Service
Bertus
Status
