After struggling with SPICE models on and off for awhile (over a year
) here's something that might be useful for some folks that are attempting a frequency to voltage conversion; a tachometer for instance.
You can use the attached with the free LTSpice, a product of Linear Technology. Google is your friend here. I'm not going to be much help porting this to other Spice versions, so don't bother asking - you're on your own.
It's a macromodel, not a component model. However, it covers the following IC's:
LM2907-8
LM2907-14
LM2917-8
LM2917-14
It's based off Russ Kincaid's macromodel for the LM2907-14, which disappeared from the Internet not long after I downloaded it.
Your mileage may vary; however the model/simulations may prove useful as a starting place.
The .sub file belongs in:
\Program Files\LTC\LTSpiceIV\lib\sub
The .asc files go in:
The .asy files go in:
\Program Files\LTC\LTSpiceIV\lib\sym\misc
The basic macromodel that Russ published is:
I rotated, re-sized and converted his original work to .PNG format.
LM2907-8
LM2907-14
LM2917-8
LM2917-14
