Voltage regulator issue
TheBellows
Joined Jan 18, 2009
56
I bought a couple of 3.3V voltage regulators called LD1117v33, now i wonder why it says 3.3V on the chip and only about 0.6V on my multimeter?
I've tried different power supplies and two vr's, but they always show 0.6V.
Something like this has never happened to the other types of vr's i've used, which always show correct voltage output, so can anyone explain me what's happening here?
TheBellows
Joined Jan 18, 2009
56
Yes i did, like i always do with voltage regulators.
There has never been a problem like this before, so i'm clueless...
bertus
Joined Apr 5, 2008
22,989
Helo,
As you see the output capacitor is larger as with "normal" regulators.
At the 78XX you will see 0.1 uF at the output, but here it is 10 uF.
What is the input voltage?
Bertus
SgtWookie
Joined Jul 17, 2007
22,230
For clarification, 100nF = 0.1uF.
Your input voltage must be 4.3v or higher. I suggest 5v to 7v. Not too high, or the regulator will get quite hot.
If you omit either capacitor, the regulator will likely oscillate at high frequency, and the output voltage will be very low. Low-dropout regulators are very sensitive to the presence or absence of the proper amount of capacitance. If your caps are too large, the regulator may shut down.
TheBellows
Joined Jan 18, 2009
56
Helo,
Bertus
I've used the right capacitor values and tried different power supplies.
My intention is to use a 9V (unregulated psu, shows about 13V with no load).
I use a ceramic 100nF at the input and a 10uF electrolytic at the output.
Are these chips very sensitive to static or something?
TheBellows
Joined Jan 18, 2009
56
One of the PSU's i tried (may have been the one i tried first), i found out was actually a 6V battery charger, may this have destroyed the regulator?
TheBellows
Joined Jan 18, 2009
56
Omg, i just noticed that the pin layout in the figure does not correspond to the actual chip...
Sorry for this, i'm feeling stupid.
Thanks for the help guys, i should get myself a reading class.
TheBellows
TheBellows
Joined Jan 18, 2009
56
Yes, my poor datasheet reading skills didn't pick that up.
A stupid mistake, but it's almost like the manufacturer does it on purpose just to bamboozle hobbyists.
Thanks guys, i won't do this mistake again.
TheBellows
