Audio filter from 1Khz to 7 Khz
august
Joined Aug 8, 2009
Please help i am newbie here. I need design audio filter which only work in 1 Khz till 7 Khz. Can anyone here help me pls!
thx!
august
fanie
Joined Jan 20, 2007
63
i am newbie here
Nice excuse :D
Do a search for Filter Lab. You can design a high and low pass filter from that.
There are about 3 different filter programmes (freeware) you can use. Some just works easier
Jony130
Joined Feb 17, 2009
5,601
Maybe this circuit will be enough
\(R1=\frac{Q }{2*\Pi*F*C1*Ku}\)
\(R2=\frac{Q }{2*\Pi*F*C1(2*Q^2-Ku)}\)
\(R3=\frac{Q }{\Pi*F*C1}\)
Or simplified equations
\(R1=Xc*\frac{Q }{Ku}\)
\(R2=Xc*\frac{Q }{2*Q^2-Ku}\)
\(R3=Xc*2Q\)
Where:
C1=C2
\(Xc=\frac{1 }{2*\pi*F*C}\)
Ku=gain
B=Bandwidth=Fg-Fd=7KHz-1KHz=6KHz
Fo=4Khz
\(Q=\frac{f0}{B}\)
\(f0=\frac{1}{2*\Pi*C}*\sqr{\frac{1}{R3}*(\frac{1}{R1}+\frac{1}{R2})}\)
Or this simple circuit
FL= lower cut-off frequencies = 0.16/(C1*R1)
FH= upper cut-off frequencies = 0.16/(C2*R2)
Au=gain=R2/R1​
hgmjr
Joined Jan 28, 2005
9,027
thx!
august
It would be useful for you to provide us with some information on your application for this band-pass filter.
hgmjr
jpanhalt
Joined Jan 18, 2008
11,087
FilterPro by TI and sloa096 (filter design application note by TI) are joined at the hip, so to speak.
Going through the calculations can be fun. The sequential process for a design described in the note is particularly helpful. FilterPro gives a graphical presentation of the response and calculates the gain bandwidth product (GBP) needed for the op-amp. I found the comparison of filter types and ability to readily observe how the response changes with different variable inputs particularly educational.
I suggest the OP go through the calculations for a simple design, but then use a program such as FilterPro to finalize his design. Note especially the effect of component tolerances on your actual results. You may need to tweak some values.
John
