360 degree potentiometer
Razor Concepts
Joined Oct 7, 2008
214
I am wondering whether 360 degree potentiometers exist, where the wiper can be rotated around continuously. I know you can modify normal potentiometers, but those have a dead band where they were not supposed to rotate. I could use two of these but I would rather just have a single potentiometer. Thanks!
Razor Concepts
Joined Oct 7, 2008
214
I tried looking for them, looks like the only manufacturer is ETI systems. But the pricing is a little high ($10+), and the only pot closest to what I want is the EUP1900, with 340 degrees of sensitivity.
Any ideas about a DIY 360 degree pot?
Ron H
Joined Apr 14, 2005
7,063
A potentiometer by definition has 3 terminals. One is the wiper. Where would you want the other two terminals connected? 180 degrees apart?
ELECTRONERD
Joined May 26, 2009
1,147
There are several digital pots you could use. Just get two tactile switches one for more resistance and one for less resistance and your good to go!
Ron H
Joined Apr 14, 2005
7,063
How do you emulate continuous rotation (360 degrees) with a digital pot?
beenthere
Joined Apr 20, 2004
15,819
Any mechanical pot has to have a dead spot or the wiper would short the end terminals.
Limitations like that are why things like shaft encoders exist.
Ron H
Joined Apr 14, 2005
7,063
It is possible to make a continuous rotation pot in which the stator connections are positioned 180 degrees apart. They may even be available off-the-shelf.
ELECTRONERD
Joined May 26, 2009
1,147
If you had a 360 degree pot, when you rotate to the maximum value the wiper would keep turning until you would rotate the wiper the opposite direction. Same with a digital pot, you would keep pushing the tactile switch until it wouldn't go any farther; if you kept pressing on the switch if it was at its maximum value, it would have no effect on the resistance until you rotate it the opposite direction. Thereby decreasing the resistance.
Ron H
Joined Apr 14, 2005
7,063
That sounds like an ordinary pot to me.
Imagine a circular resistance element, with taps 180 degrees apart, and a wiper, but with no stops on the rotor.
PackratKing
Joined Jul 13, 2008
847
I see no mention of a precision 10 [ or more ] turn pot............
I used one of these marvelous contraptions [ clarostat ] in construction of my bench power supply, [ 0 - 24 volt, 4 amp DC ] to enhance control over its output that a "normal" 270 deg. 5K pot wouldn't give.
The only other option I am familiar with, is a vernier control, which is nothing more than a calibrated gear reducer, and will allow any number of 360 deg. turns to cover the 270 deg. range of that "normal" pot.
ELECTRONERD
Joined May 26, 2009
1,147
Well, all the normal pots I have stop at the maximum, and minimum points. This would be continuous.
