iam designing spwm inverter. The output of the inverter should be sinusoidal. This is the first step of my project. i dont bother about the harmonics. I need to show an approximate sinusoidal, atleast 50% tolerance. The output voltage of the inverter will be around 12V AC.
<snip>
Iam not going to connect any load here. I just want to show the output in an oscilloscope. so, the load current here is very less. The DC input im giving is a 12V rectified supply (op from 7812).
can u suggest me suitable static switches. (either mosfet / igbt / even transistor).
Im using two XR2206 ICs. One for sine and the other for triangular. I have used LM324 to compare them. I got the pulses only on positive side. ofcourse i have used single supply.
<snip>
