Switch 12 volts using micro controller
bsfrye
Joined Feb 20, 2009
23
I need to switch 12 vdc 10 amps on and off using 5 volts from a micro controller. I assume this is really simple - just not sure the best way to do it. Any ideas? Like I said, I am sure this is simple, I am just compeltely new to electronics.
bertus
Joined Apr 5, 2008
23,006
Is the 10 Amp load connected to ground or to the + 12 Volt powersupply ?
May the driver directly connected to the micro or do you want isolation ?
Greetings,
Bertus
bsfrye
Joined Feb 20, 2009
23
it is actually a 12 volt dc motor. So I guess teh 10 amps is to power? I don't need anything fancy, I don't need to control speed, or direction, or anything... Just turn it on and off.... It is 12 volts, and draws 7 amp MAX current.
