Diode work
beemovie
Joined Dec 19, 2008
12
Hi !!!
first of all best wishes, Today I have encountered a h.w question which I cannot understand.Please help me out through this. If you can please when you answer write the question number so that I han recognise to which one you're refering.I am still a Beginner.10x
The diode is silicon in the diagram. Using the second approximation method calculate :
1) The load voltage
2) The diode voltage
3) The diode current
4) The diode power
5) The load power
HELP ME !!!!
thankyou for now
bertus
Joined Apr 5, 2008
22,964
To solve the question you will need the properties of the diode.
What is the voltage across the diode ?
When you know this the voltage across the resistor can be calculated and its current.
Greetings,
Bertus
bertus
Joined Apr 5, 2008
22,964
You must know the properties of the diode to get an answer.
It is said it is an silicon diode, I think the forward voltage will be around 0.7 Volts.
Now calculate the voltage accross the resistor, then you can calculate the current and the powers.
Greetings,
Bertus
beemovie
Joined Dec 19, 2008
12
Hello
First of thanks for your help Bertus....
I will try to solve this out !! I need to someone confirm it please!!!And help me through 4,5 suggest me which calculations I have to use
1)the load voltage...... V= 10-5=5V
2)The diode voltage......Considering it is a silicon diode it is 0.7v
3)The diode current.....I=V/R.. I=0.7/1000= 0.0007mA
4)The diode power==??????????
5)The load power=?????????
bertus
Joined Apr 5, 2008
22,964
That is not completely correct.
There will be about 0.7 Volts across the diode, this has to be subtracted from the 5 Volt you calculated.
Greetings,
Bertus
beemovie
Joined Dec 19, 2008
12
I'll try it again please confirm it for me and someone help me through 4 and 5
3)The diode current.....I=V/R.. I=4.3/1000= 0.0043mA
bertus
Joined Apr 5, 2008
22,964
You are still giong wrong.
1) The load voltage : Utop - Ubottom - Udiode = 10 - 5 - 0.7 = 4.3 Volts
2) The diode voltage : Considering it is a silicon diode it is 0.7v
3) The diode current : Uload / Rload = 4.3 / 1000 = 4.3 mA
4) Power current : Udiode * Idiode
5) Power Load : Uload * I load
Now continue.
Greetings,
Bertus
