All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 09-19-2007, 07:36 AM
b_frozt b_frozt is offline
Default Digital Dice
i got problem on designing this digital dice, we were told to use "combinational circuits", but i dont know how. i saw some circuits which use 555 timer and 4017 counter, but are these ICs for combinational circuit(opposite of sequential circuit)? and even though they are allowed, how do they function? can anybody help please? tnx!
  #2
Old 09-19-2007, 11:05 AM
cumesoftware's Avatar
cumesoftware cumesoftware is offline
Default
I think I saw that project once, but I cannot do anything without a circuit. Post the link to the page, if you please.
__________________
I love the smell of toasted transistors in the morning.
  #3
Old 09-19-2007, 03:22 PM
Default
http://www.electronicsforu.com/elect...Digital%20Dice
http://www.kpsec.freeuk.com/projects/dice.htm
http://www.talkingelectronics.com/pr.../LED-Dice.html
i like the first one because it uses logic gates outside the ICs, but i dont know what the gates do because i dont know the inputs to the gates which are the outputs from the 4017 counter.
  #4
Old 09-19-2007, 04:44 PM
Default
Basically, the 555 is in astable mode and provides pulses to the 4017 counter. The counter "counts" the pulses, changing its output each time it receives a pulse, in the sequence:
Q0 1 2 3 4 5 6 7 8 9
1 0 0 0 0 0 0 0 0 0
0 1 0 0 0 0 0 0 0 0
0 0 1 0 0 0 0 0 0 0
...and so on.
In the second project, the logical combinations required to light the LEDs are made using diodes. The Q6 is used to reset and go back directly to Q0. Instead of using diodes, you can use gates to light up the LEDs. The second project is the best, since the touch plate should be avoided. You should stick to TTL or CMOS only (the CMOS family can drive well LEDs and you can use a 9V battery to power them directly). Using the 555 timer to activate the 4017 chip is bad practice. You should go to the CMOS version, the LMC555.
__________________
Bookmarks
Tags
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Digital Elevator Simulation sndp_2002 The Projects Forum 7 01-23-2008 07:49 AM
Digital Dashboard (circuit review) weegee The Projects Forum 6 05-11-2007 05:37 AM
digital display for magnetic field pratapkollu The Projects Forum 8 03-13-2007 09:33 AM
MAX333A(analog and digital parts) Crowbar General Electronics Chat 7 01-14-2007 03:49 PM
Interfacing of Digital Circuits with Optical Fibre sukhminder General Electronics Chat 0 10-08-2004 01:28 AM
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License. Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
