Digital dice game
Discussion in 'The Projects Forum' started by bustamantecami, Mar 20, 2012.
  1. bustamantecami
    Mar 20, 2012
    Hi, I'm a newbie when it comes to building circuits. and i need to make a dice game for my project in class. basically what it does is there are two players both have their own push button. they both push the button and who ever gets the higher number gets a point. the winner is the one who gets 7 points first.
    now my problem is that i need a circuit that would compare the two outputs then increment the points of the winning side. i tried using a comparator and connected it to a circuit that would increment a seven segment display but it doesnt seem to work right. the circuit is attached so you can better see what im talking about.
    thank you in advance!!
  2. n_adam
    Mar 1, 2014
    19
    Did you have any luck finishing this project? I am planning on building a similar game for my digital class final project, and I was trying to figure out the comparing and score incrementing logic.
  3. ScottWang
    Aug 23, 2012
    4,929
    777
    If you could attach the clear jpg file that is better for the most members to help you.
    absf likes this.
