Can we use a tristate buffer in place of voltage level shifter?
sharath_412
Joined May 7, 2007
32
We need voltage convertion from 5 volts to 3.3 volts( TTL compatible).
For this can i use a tristate buffer ( supply =3.3V, input voltage range is -.5 to 5.5 volts, o/p is TTL compatible) in place of a level shifter( Vcc=3.3).
Q1. In the datasheet of tristate buffer he specified currents for logic 1 and logic 0 as
logic '1' output current -20 mA
logic '0' output current +20 mA
Is this same for all tristate buffers?
When we connect some component at the o/p of that tristatebuffer what are the issues I have to take care about?
thanks
sharath
bloguetronica
Joined Apr 27, 2007
1,544
thanks
sharath
Where is the datasheet? Are you refering to open collector outputs? You can use those for that.
I sense a confusion between tristate gates and open collector outputs in this forum.:D
lightingman
Joined Apr 19, 2007
374
There are a range of gates that will do this.... 74LCXxxx series.They will run at 3.3v VDD, but have 5v tolerant inputs.Or check out the CD40109.Daniel.
