great site, will refer it to my son to learn from.
found an error in the text vol 1 - dc ohms law
http://www.allaboutcircuits.com/vol_1/chpt_2/7.html
It also means that voltage measurements between sets of "electrically common" points will be the same. That is, the voltage between points 1 and 4 (directly across the battery) will be the same as the voltage between points 2 and 3 (directly across the resistor). Take a close look at the following circuit, and try to determine which points are common to each other:
should read, perhaps.
It also means that voltage measurements between sets of "electrically common" points will be the same. That is, the voltage between points 1 and 4 (directly across the battery) will be the same as the voltage between points "4" and 3 (directly across the resistor). Take a close look at the following circuit, and try to determine which points are common to each other:
no biggie as the text is very descriptive, just a typo
